If you want to go on the cheap for personal use, buy the OTC press and go to HF and buy the adapters. If you want USA made, you can do what I did and get a BJP1 and not look back. I have seen a HF press bend but so far, the OTC presses that I have seen are holding up OK.
I like the way that the BJP1 adapters snap onto the press to make using it an easy one man operation. If the OTC 8031 snaps together like the BJP1, it would be a good alternate for the money. The only problem I have with the Snap-on press is the screw. In my opinion, it should have Acme threads instead of std threads to make things easier under load.
