I have shopped around and tried many offerings (Hansen (my preferred for 'through' sockets), Mechanic's Time Savers (great concept, a bit cumbersome), Craftsman (good, not great), and Kobalt (Not US made, I know)), and IMHO the Hansen trays are the clear winner for 'through' sockets.
Advantages of the Hansen trays:
- Clear identification of system (metric vs. SAE) via gray or red plastic
- Clear identification of socket size on the top of the individual post
- Comprehensive range of socket sizes on each tray, 1/2" metric notwithstanding (26mm is omitted)
- Reasonably priced (not a bargain, but no need to break the bank)
- Efficient use of space compared to most trays in that every socket, when stored, is equidistant from the adjacent socket regardless of size
Shortcomings of the Hansen trays:
- PLASTIC! I have snapped some posts on the Hansen trays, and had to repair with JB weld (with success). I wouldn't hesitate to replace all my Hansen trays with an equivalent machined aluminum offering.
- The printed text on each post would be better if it was colored and raised / embossed. Disclaimer: I haven't worn off the lettering on any of mine, but I suspect that a harsh degreaser / solvent would do the trick.
- They lack mobility. Take this for what it is, as the Hansen trays (to my knowledge) were not designed to be packed back and forth to a job. They were designed to sit in a drawer and not be moved frequently
Now onto the
Craftsman trays. I still store my 1/4" Craftsman sockets on one of these trays, and it works fine. These were offered a while back (I think I purchased mine ~10+ years ago). They are still offered by Sears here:
http://www.sears.com/craftsman-103-...0965287000P?prdNo=15&blockNo=15&blockType=G15
Advantages of the Craftsman 'peg' trays:
- Modularity: The interchangeable pegs allow the user to configure the boards with varying drive sizes: 1/4", 3/8", 1/2". This is useful for organizing socket sets that span through various drive sizes (See torx set above).
- Ease of socket removal and return. The locking style has its advantages, but if the tray sits in a drawer exclusively, it's a bit overkill. The sockets easily slide on or off the round pegs and don't tip over when opening or closing a drawer.
- Pegs do not extend through sockets, which allows the user to organize bit sockets and other sockets that would not allow a post to extend all the way through.
Shortcomings of the Craftsman 'peg' trays:
- PLASTIC! The tray itself is pretty flimsy, and the center of it sags when under the lightest load, causing the sockets sitting atop to stand at an angle.
- The trays measure ~8" x 6.5", which is pretty small if you're trying to organize a lot of sockets.
- The trays are not mobile at all. The plastic tray is so flimsy that if you try to pick it up while it is loaded, you will be picking up all your sockets off the ground.
All things being equal, I'm not a big fan of these, and wouldn't buy them again.
The tray I use to organize all my 'specialty', i.e. random, sockets is the
Kobalt socket tray ~$25. The rails are plastic and riveted to an ~18 ga. steel sheet. It sits in the top of my cart and I don't ever take it out, as I just roll the cart to any job. What I like about the Kobalt tray (similar to the Ernst) is the narrow clips that attach the socket to the rail that allow sockets to be snugged up against each other so that the tray's footprint can be utilized 100%.
Advantages of the Kobalt socket tray:
- Clips are narrow enough that sockets can be snugged up against each other.
- Clips are easily removed and installed so that combo drive socket sets can be organized with ease
- Friction ball 'locking' system locks the socket to the rail well enough that the tray can be inverted without sockets falling off, but not tight enough that the the operator picks up the entire tray when trying to remove one socket.
Shortcomings of the Kobalt socket tray:
- Socket clips are not sold separately, so if the included number of clips does not suffice, you either have to live with it, or buy another tray just for the clips.
I don't have much experience with the
Mechanic's Time Saver trays, but what I do not like about them is the unavoidable fact that the sockets must be spaced according to the wide locking clip which houses the 'twist lock' mechanism. See below:
You all sound pretty set on the Westling trays. I have never seen one in the flesh, but sounds like I should hop on the bandwagon.
Cheers
