bd8134
I hope you can advise me on this.
Not garage related, but if I can resolve this I can get back out there..
I want to keep everything to electrical / MA state compliance.
I just put in a master bath. I have a towel warmer that I want connected to an electric under floor timer / controller.
The electrican ran a 4-wire romex from the outlet where the towel warmer is (approx 1.2A load), and also where the supply comes in, to the opposite wall where the floor warmer controller is (approx 3.4A load).
At the controller end, for the 4-wire romex, the white and black are used for supply and the red is connected to the load output on the controller.
Back at the towel warmer end, the red supplies 120v to the towel warmer and the white is taken from the common white in that box.
The problem is that the towel warmer controller has a GFCI built in which trips when the towel warmer is switched on. It is because only the one wire /load for the towel warmer comes from the controller (the red wire), the white is taken from the common in the towel warmer box. Hence the GFCI detects a different load across the 2 wires.
It is not possible to run another wire between the 2 boxes.
I do have a ground wire that is in the romex. At present it is just connected to the metal braid / shield on the supply wire to the electric elements under the floor. The timer does not have a ground connection.
Can I use the ground wire in romex as a neutral?
I have a GFCI in the panel.
My other option is to run another supply from an outlet box that is underneath the timer box but is on another circuit.
