edl
if you wanted to use a window unit inside (that is, no part of it through the wall or a window, the unit completely inside) how would you
1. exhaust it - build a wood box around the rear and side exhausts and reduce to a vent tube? other?
2. what about the water - are these designed to drip water? it seems as if they have a tray that catches the water - is it supposed to overflow from there? - could you cut a hole in tray and draing into tube on bottom? - does it need any of this water for cooling purposes?
the reason I am asking all this stuff is because Sam's club sells a ge window unit that is a whopping 24,000 BTUs for 372 bucks - if a minisplit alternative is something like 6K installed (at least according to another post) - 24K btus for under 400 bucks???? pls help me out so i can use this thing!!! - here are a couple of pictures, but they don't exactly give me the answers - thanks!! ed
