FunkyfullWidth
Stumbled upon a decent deal on a compressor at a local antique shop. It's an 80 gallon 2 stage AMP. I found a few posts on the web about it but with no real info. Best I can gather is that it's a saylor beall 705 clone. Intercooler and aftercooler. 200 psi tank. Tag says it's cut offs are 145-175. Stamping on the tank puts it as a 1994.
When I initially looked at it the tag said 500 bucks. I snagged it for 450. The guy had a forklift to help load. Unloading was a tad trickier. My motor puller got it done, but it was hairy. First things first after getting it off the truck was a good once over. I took off the after cooler, belt guard and charge air tube to get a better spot to pick it from. I cleaned it all up and reasealed the pipe threads. I checked the oil, cleaned the air filter out, pulled the drain and the big plug off the front. OH BOY. FILLED with rust. And this is after I scraped and vacuumed it out for a while. There was almost 3 inches of scale built up. The drain was clogged, the safety releif under the gauge was clogged. ugh. Nightmare.
This thing must NEVER have been drained. The plus side. Compressor sounds good. I let it build to about 40 psi to check all the connections and safety valves for functioning. Unloader valve leaked and I'm thinking stuck check valve. The guy claimed that the motor was newer. So either way I'm ahead of the game I feel. I got a nice schrader bellows regulator and a parker filter with it.
My plans. I'm gonna wire it up and enclose it under my stairs. Eventually I plan on getting a new tank for it. I'm gonna go horizontal. I priced out tanks and new you can get them for about 500-600 bucks. But probably more. The oil company I work part time for has sonic testers for oil tanks. I'd like to try it out on this tank.
Moral of the story. When buying a used compressor, bring along the biggest pipe wrench you can and peek inside the tank. Because if your like me, jumping into **** and having zero good luck your gonna get bit.
