Used Fire/Chemical Cabinet Value
W_KY
Bowling Green, KY
While on craigslist today I found some used chemical cabinets for $100 each. I can't tell their exact size but the guy says they are about 6 ft tall. I'm thinking that is a pretty good deal and I should go by both he has left. What do you think? I'm guessing these are fairly heavy duty.
Colin Len
Long Beach CA
I see these sorts of things on my local CL a lot for significantly more than that - think $250-$1000 depending on the size/condition/seller...etc. Not sure if anyone is buying at that price, but that's what they seem to list for. Maybe a good deal compared to buying new if it's specifically what you need, but seems really expensive for someone just looking for basic metal cabinets like most of us. But at only $100 that seems like a reasonable price since the lighter duty (non fire/chemical) versions seem to sell for $40-100ea.
rlitman
Long Island
Nice find. Grab them if the doors aren't falling off. But Justrite uses piano hinges, so they take an incredible amount of abuse.
DIC
If you need a fire proof cabinet and they are in good shape I would jump on that deal
superdutymike27
SE Wisconsin
I was doing some work in a hotel several years ago and noticed the building engineer had 3, 45 gallon cabinets, ( not sure if I Am describing that correctly) but to make long story short I offered him $100 for one of them and he took it. I had the chance to buy the rest of them but never made it back. I don't have mine vented but probably should!
kaffine
Henderson, NV
If I saw ones that cheap I would be getting them. I typically see the large ones starting around $500. Every once in a while I will see them down around $300.
Even the small ones go for over $100 here.
Beater5liter
Central Ohio
I got a smaller single door version similar to yours off CL. Bring help as that size one is going to weigh well north of 300#. Those things are deceivingly Heavy!
CNGsaves
KS and OK
Considering lots of CL sellers want $75 for paper-thin steel flopsy cabinets, I'd jump all over those at $100 each.
Trailer with ramp . . . . dolly . . . .and strong buddy to snag both. Go get 'em!!
Let us know WHEN they're in your shop . . . . with PICS !!! :D
Big Bad Dad
Southwest/ Central Va.
I would like to have that to store all my gas cans in. I don't like to keep them in the garage, and while I now store them under an open shed, it would be nice to lock them up. (I had a full can stolen a couple years ago.)
MushCreek
Upstate South Carolina
Great deal if they are in serviceable condition. New, they are around $800 for that size. They usually bring about $400 or so at auction. I bought one about that size for $50 at a county auction. Mine is in excellent condition except for the crappy brush paint job that some county worker just HAD to do.
LS6 Tommy
Northern NJ
Sounds like a good price, but the pic leaves me feeling "iffy". The doors are ajar. They're supposed to auto close and latch. They're also pretty rusty...
Tommy
LS6 Tommy
Northern NJ
Not all of them auto-close- in fact, I've never seen one that did, although I know it's an option.
You're correct. My memory is going. The doors don't have to auto close unless its a wood fire cabinet. They all have to have a 3 point latch...
Sorry for the bad info!
Tommy
W
W_KY
Bowling Green, KY
I ended up buying two of them. They are heavy. It's a good thing the guy selling could help me load them. They don't have shelves and I have to work on the latches but they are built really well. One is a justrite and the other is s secural. Each about 65 inches tall. Later I'll probably clean them up and maybe paint. I'll post more pics later. I did Google one of the models and it is $1300 new
MushCreek
Sweet deal! Some day, I'll paint mine properly, but it's at the end of a long list. I keep everything flammable in mine- solvents, oils, oil-based paints, etc. Cheap insurance to protect your shop.
Dennis Leigh Henry
South Central, IN USA
Yeah.. That is quite a score for $100 ea. You could do a whole lot worse. I believe Justrite sells spare shelves if you want to go that route, or hit the local sheet metal shop and have them fab some up (or do it yourself if you have the skills / equipment).
I purchased one for my basement workshop back in Dec. This string is the start.. eventually painted it, placed it, and replace labels etc.
Dennis
http://www.garagejournal.com/forum/showthread.php?p=4477638#post4477638
kansei
Greenville, Michigan
I used to work for a company that made these types of cabinets (Protectoseal). We competed with Just-Rite, Eagle, etc. I have two 45 gallon and two 60 gallon cabinets from those days. If you decide to use the vent, make sure it still has the flash arrestor in place, otherwise it defeats the purpose of the vent. If all you plan on storing in the cabinet is cleaners, spray paint, etc., just unscrew the vent plug 3/4 turn or so and it should vent any pressure build-up fine. Make sure you ground the cabinet properly, though. I can't tell you how many industrial plants I visit that have flammables in these types of cabinets, yet do not have them grounded to eliminate static electricity spark hazards.
Neal.
rsanter
visalia ca
Several years ago I saw one put out on the curb for trash pickup.
I grabbed it and then sold it for $250
Bob
kansei
Something I forgot to mention- if you do repaint them, make sure you either use non-conductive paint designed for explosive/flammable environments, or you absolutely NEED to properly ground the cabinet. Having a dedicated grounding rod for the cabinets of the same specs you would use to ground a distribution panel is a good idea. Never use the building wiring ground circuit!
Congrats on the score!
Neal.
mikegt4
sw ohio
After reading this thread I checked the local CL just for fun.
35" wide 22" deep 35 1/2" tall, $175
23" wide 18" deep 44" tall, $75
Apparently typical prices judging by this thread. When I was working we "surplussed" several flame cabinets of various sizes. Company policy prohibited selling them or giving them away, only sold to scrap companies. They are a good piece of equipment for any garage.
CNGsaves
KS and OK
OP . . . getting two of those cabinets at $100 each is just like getting StrongHold cabinets for a song. Both are heavy duty and last a lifetime.
So for $200 . . . you've got damn sturdy cabinets . . . AND . . You **** !! :thumbup:
Dennis Leigh Henry
Neal.
Another great GJer providing outstanding tips and help to those of us on this board. Thanks a ton Neal, I'm sure we all appreciate the advice..
Dennis:beer:
bob15
Northeasten, CT
Zoro sells extra shelves for the Justrite. Just wait for a coupon to come.....
I have similar cabinets myself and needed more shelves.
galute
Bald Knob AR
I bought these at a farm auction. I gave 25 bucks for the pair. I was the only bidder. One is missing a handle.
bob15
Northeasten, CT
Could you give me more details on Zoro..? I need some shelves too.
Thanks...
They are part of Grainger, but cheaper in price. Free shipping over $50. Their search isn't the best, so i go to grainger, find what i want and they copy over the part number into the zoro search function.
http://www.zoro.com/
Here is the Justrite search result page....with extra shelves (they sell other safety cabinet brands as well):
http://www.zoro.com/g/Safety%20Storage%20Cabinets/00055389/
sleepy127
Flaherty, KY
I have been looking for some myself. I would grab them if I was you. If you have a lot of chemicals to store they come in handy. I use an old army locker for mine and keep it outside.
sberry
Brethren, Michigan
You cant buy nuthin in it for 100$, you could fab the heck out of it and would make great foremans desk or tool box. Those are nice and well built, the seller isn't robbing anyone at 100 a piece.
This is a place a guy can really score used deals and get stuff way better than he would ever consider new.
Super paint cab. Put 2 side by side, one for equipment and mix station and the other for material.
sberry
Brethren, Michigan
Always use the building grounding point, it should be electrically grounded.
I don't know anything about fire codes and havnt studied NEC in that area but I suspect that there might be a requirement for bonding similar to a gas line.
