Used Husky 80 gallon compressor value?
Citation
Indy
Which one? I think the cheapest were single stage, 3 cylinder for around $800. They also have some better 2 stage compressors that were in the $1200-1500 range.
T
tom-ky
Morgantown, Ky
All I know is the pic shows a red Husky, says Pro on it. Gauges are mounted on it in the motor/pump bracket. Auctioneer thinks it will be reasonable.
Citation
Indy
Can you describe the pump or find a picture of a similar one in line (Google image search for 80 husky pro compressor)
Citation
Indy
That's exactly the one I scored not long ago. It's currently in my father's garage.
From what I could find its a 4hp, 12 cfm @ 100+ psi Campbell H pump. Basically your entry-level two stage compressor. It's about $1200 new and the newer versions have a bit more cfm. It does have a remote drain but that didn't work on the one I got. I wouldn't pay the $1000 from that link if that happens to be the asking price.
redmondjp
Redmond, WA
If it's at an auction and you can't see it run, you have to assume worst-case and assume you'll need a pump or a motor and price it accordingly. Now it may be perfect, I get that, but what if the motor is fried? Add another $300 right there.
If it was me? I'd probably pay up to $500 if it was in pristine condition, $300-400 otherwise.
Don't get auction fever - it can be a long recovery for your wallet.
T
tom-ky
Morgantown, Ky
It is at an auction. I know the auctioneer and he is supposed to take a video of it running and send it to me. He thinks it will bring no more than $300.
Here is the actual compressor:
