Used mini-split
minerfarmer
Central Illinois
I bought two of these units at an auction to heat and cool my 20X36 shop. Plan is to get one hooked up and have a local HYVAC guy charge it. I will have the other for spare parts or to sell if all works out. It does not appear that these units were sealed when the lines were unhooked. They have been setting in a warehouse for a couple years. What kind of problems should I expect? Anything I should do before I get them hooked up?
brewchief
If they weren't sealed they will have moisture in the oil, the oil used with 410a holds moisture and it cannot be removed with a vacuum, only with dryers, it may take multiple dryer changes to dry it out, good luck.
minerfarmer
Central Illinois
Tell me more about this dryer thing.
abbiepeach
You'll contact an HVAC guy who'll do the thing on the other unit, right? I think you should also let him inspect the unit, too, just to be certain that the unit has no issues.
Falcon67
Merkel, TX
The dryer thing removes moisture from the refrigerant. However, it's not designed to remove much. AC systems are pulled down with a vacuum for at least two reasons - one to boil out all the moisture and two to check for leaks. So if the oil won't give it up under vacuum, you'll have to force it out with an oil change and maybe multiple dryer changes.
WHAT DOES A DRIER DO- DRY?
IT'S NOT THE FREON!! It's the oil in the refrigerant that absorbs moisture and holds debris in the system. Replacing the drier / accumulator, in addition to evacuation, will assure better performance.
Why Replace the Receiver-Drier?
The receiver-drier must be changed each time a system is empty regardless of the reason for loss of refrigerant. It should also be changed every three years, because the desiccant pellets will break down and clog the expansion valve. This will in turn cause the system to become inoperable and May damage the compressor.
The receiver-drier is strictly a disposable item and is thought of in the same terms as a fuel, oil, or air filter. In fact, if any component fails or is replaced for any reason, the receiver-drier must also be replaced to prevent corrosion and moisture in the system.
The receiver-drier performs three functions:
-It filters the system of non-condensables.
-It receives the liquid refrigerant and maintains a certain level of liquid at the bottom at all times in a properly charged system.
-It contains a stack of pellets called desiccant (drying agent) to trap and absorb moisture. NOTE that moisture is the most harmful enemy of the air conditioning system. If any moisture is in the system, it will combine with the refrigerant to form hydrochloric acid which is extremely corrosive to metal components.
Replacing the receiver-drier is essential when servicing the A/C system. Whenever you replace a component of the A/C system you must also replace the receiver-drier. If you do not change the receiver-drier there could be serious damage to the other parts of the system, which could be very costly. You must also have proof of changing the receiver-drier in order to receive a compressor warranty."
