nate379
No one takes oil around here. None of the auto parts stores, not Walmart, etc. I was giving it to a friend that heats with it, but he ran out of room for storaging more, has a few thousand gals I guess.
That funnel will flop over and screw you if you don't watch it. However, my problem might be that I'm usually draining three gallons at a time out of a big pan so I'm dumping more weight in oil than it wants to handle. I have a bunch of junk piled up so there are usually leaves under stuff, I rake up a pile of leaves and set the bucket in the middle of the pile. Any spillage is soaked up by the leaves and then it gets raked into the burn pile.
It's a 40 mile round trip for me to the nearest recycling center so I don't bother wasting the fuel to go there. I just dump it a gallon or two at a time into the fuel tank on my old F350 diesel pickup. It loves the stuff and it's worth 4 bucks a gallon as fuel now.
I got the brainwave to use an automotive oil pump driven by a drill. It works awesome and will also **** the oil out of smaller containers used for bikes etc.
Split spouts...
