Assuming quality brands and that both types have memory pointers, if you're purchasing a used torque wrench, flat beam or dial?
As I see it, dial wins in terms of granularity of graduations, they're more compact, smaller dial face to keep an eye on while working with it. Problem is whether the thing is accurate or has been over torqued... as far as I know you can just turn the bezel to align zero with the needle? Do they tend to need recalibration over time?
Flat beam, or at least the brands I'm looking at, should be extremely accurate (a couple percent more than a dial) as long as the pointer is at zero while resting, and should continue to stay that way forever if not abused. The problem is the graduations tend to be not as granular vs the dial wrench, and the dial face in the beam is a bit more cumbersome in terms of clearance and keeping visual sight on in use.
