Useful shop cheat sheets, charts for printouts
Whiskeymike
Austin, TX
I've started creating a binder of useful shop references that I can print out and keep in the binder without having to google each time. Here are some of the things I've found -
Jeep JK Torque specs - http://project-jk.com/jeep-jk-write-ups/jeep-jk-wrangler-torque-settings
Several Bolt & Fastener charts - https://www.boltdepot.com/fastener-information/Printable-Tools/Default.aspx
Fractions to Decimal & Metric - http://www.americanpunchco.com/fractions-decimals-millimeters-conversion-chart.htm
Electronics - http://wiki.smallroom.net/doku.php?id=electronics:general
Mig Tips - Hobart - http://www.hobartwelders.com/elearning/pdfs/MIG_Welding_Tips.pdf
Stick Welding - Hobart - http://www.hobartwelders.com/elearning/pdfs/Stick_Welding_Tips.pdf
Hobart 190 Guide for material thickness & settings -https://www.hobartwelders.com/pdf/spec_sheets/Handler_190.pdf
Miller Guide - http://www.millerwelds.com/pdf/mig_handbook.pdf
Added these per AMCguy's recommendations
Drill Speed Chart - http://www.abrasivestore.com/products/dynabrade-13/p134-135chart.php?lg
More in depth version - http://www.free-ed.net/sweethaven/IndustrialTech/machinist01/default.asp?uNum=3&iNum=0408
Sheet Metal Gauge (Thickness) chart - http://www.davidsonsales.com/docs_pdf/sheet_metal_gauge_chart.pdf
Another with weights - http://www.mcnichols.com/resources/gauge-chart
Added per Bwringer's suggestion -
Tap/Drill sizes - https://littlemachineshop.com/Reference/TapDrillSizes.pdf
Added per Grinder Bill's suggestion -
Bolt Specs - http://www.engineershandbook.com/Tables/torque.htm
What reference cheatsheets/guides do you find useful?
Mike
snowman3
Arizona
wow, thanks for bolt depot! Was just there yesterday looking for pilot hole sizes, but your summary page is best place to start. Thanks!
MushCreek
Upstate South Carolina
Metric threads don't require a chart. You just subtract the thread pitch from the diameter. So if it was a 6mm thread with a 1mm pitch, you would use a 5mm drill. The same thing works for SAE threads, but it's more complicated. A 1/4-20 thread has a pitch of 1/20 of an inch, or .050". Subtract .050 from .250 (1/4 inch) and you get a drill diameter of .200. A #7 drill (.201) is commonly used. Handy to know if the tap you're using isn't on a chart, or if you don't have a chart.
I like having speed and feed charts handy for machining. It's quicker than figuring it out. For most normal diameters, I have a pretty good feel after 40+ years of machining, but when you get extremely small or extremely big, you need to know how to figure it, or have a chart.
I've always wonder why calculators don't come with a metric conversion button- maybe the fancier ones do?
A lot of stuff I just look up in the Machinery's Handbook.
RedRabbit
SoCal
The machinary handbook is amazing but I was at Barnes and nobles and picked up a shop refrence manual for engineering students and it is a bit better in my opinion.
DC73
Lubbock TX
Which reference manual are you recommending?
Thanks,
DC
Grinder Bill
Divcod
Thanks for the link to useful references. I purchased a used machinist handbook for $3.00 from Powell's Book in Portland OR which includes many shop references but also has formula's for many layout calculation. Book was published in the 40's but has been a addition to the shop.
Vegaman_Dan
Pacific, WA
I have refs for metal Guage and welding settings printed out and laminated so they stay clean.
Engine rebuild checklists are also handy this way as the laminated plastic works with dry erase markers.
skulldrinker
Bolingbrook, IL
I'm old school and when I had to start dealing with Metrics I made this cheat sheet and have it hanging on my box. Helps me deal with what size MM is near or equal to an SAE size. Also helps when I need the next size larger or smaller.
sizem
kentucky
I made a fraction to decimal chart that I use almost daily.
I can easily estimate that a decimal is approx 1/16 and 1/2 and tweak my wood saw, etc appropriately.
Enjoy!
  • Chart Fractions to Decimals.pdf
RoninB4
Under My House
-It was real nice of the OP to compile these charts for everyone to use, a very nice gesture.
-I will comment that not all the sizes listed in the above chart should be taken as gospel. A quick perusal through the "inch" sheet revealed at least two different sizes for "close fit" and "free fit" that I didn't agree with. There may be more, I didn't check the metric sheet. What was listed isn't wrong, per se, but there's a better "close fit" and a far more common "free fit" than what's in the chart for those two sizes. Not trying to find fault or throw rocks at a generous effort by the OP. What I'm saying is don't trust some chart on the internet blindly. Verify numbers before deciding if it's something to follow.
rharman
SoCal
I bought this so long ago, I can't even remember. Looks like it came out in 1969 but I'll guess I picked it up 4-5 years later. Filled with soooo much useless information along with a ton of useful stuff too. I still refer to it for drill, tap, pilot sizes, etc. It's kind of cool/retro. There are newer versions available on Amazon and others.
rharman
SoCal
So, here's a taste of some of the "useless" info from that book....
Need to dustproof your tennis court?
--or--
Need to make silver jewelry from dental amalgam?
Jgaz
This is my new favorite chart.
With the chart I used for the last 40 years I always had to use a separate chart for the metric sizes.
