Uses for old engine oil?
Bennylava
Cleburne, TX
What do you do with your used motor oil? I wanted to get a small waste oil burner to heat the garage in the winter, but it seems those aren't common enough in texas to be cheap. I guess you'd have to route an exhaust too.
Have you ever found any other use for your used motor oil? Or do you just drop it all off at autozone? I'd really like to find some good use for it, rather than just giving away a free fuel. I paid for that oil dangit!
Gmonkee
Release oil for cement forms to the local builders. I buy nearly none but sell gallons from a friendly mechanic.
Shiftless
East Bay SFO
It's pretty good for starting brush fires. A bit smoky but it works.
Long ago I was visiting a relative who had recently moved onto a few acres out in the woods with his single wide. He had a circular clearing about 100 feet across, he had a big pile of branches and slash heaped up in the middle maybe 5-6 feet tall and at least 10 feet across. He wanted to burn it. He started with a gasoline can and walked around the edge sprinkling it on. I told him to go easy ‘cause it’s gonna basically explode by the time the vapors accumulate in the brush. He said don’t worry about it. He discounted my warning because I was just a city boy. I backed up a lot. He tossed in the match.
I was right. Impressive fireball. Luckily no trees caught fire.
DON’T USE GASOLINE TO START BRUSH FIRES
I think used motor oil would be Ok
