Overlord66
I have 220 irrigation pump that was wired wrong and needs to be corrected. I have 1'' conduit from the garage to the the pump room. The circuit was wired with 12ga romex from the panel until the pull head that leads outside. I planned on using 12ga thhn in the conduit all the way to the pump. My dad showed up with 4 brand new spools he had laying around. When I looked at them they are 10ga.
This is a 20 amp circuit can I use the 10ga thhn in the conduit or should I go buy 12ga.
Also what is the fill rate if I use 10ga? Could I add another 10ga 110 circuit to the conduit with out over filling it?
