Hello,
Im new the board and I am novice with electricity. I need a little help. Please excuse my lack of knowledge with this particular topic.
I am trying to split a 200amp feed at my building. My current setup has the line coming from meter in the meter room to a empty panel. A tenant in the same complex has a setup I would like to duplicate. They have the line(2/0 3 wire with bar aluminum ground) from meter going to a box that I am guessing is a splitter box or junction box with a distribution block(The box is not very accessible to confirm what is enclosed). From the splitter box, one line goes to a panel and the other line goes to a 100Amp safety disconnect then to a panel.
My first question is what guage wire would i use for the run from the splitter box to the panel and safety switch? 2/0? Or 4/0? The length from box to the furthest panel is 30'.
MY second question is I cannot find splitter boxes but I can find distribution blocks. What do I do with the ground as i have not seen any block with a ground? Would I get a grounding terminal bus bar? What type of distribution block should I use(3 pole) or how would I configure this box to split the line into Two 100amp lines?
Thank you.
Thank you.
A breaker protects the load and the WIRE !
