Using 55gal Plastic Barrels for Culvert?
IdahoMan
As an alternative to the traditional metal/pvc culverts, what about large plastic drum/barrels connected end-to-end?
Question(s) would be:
Would they be able withstand the pressures (depth considered)?
Is there a good way to connect them to prevent leakage (maybe some kind of adhesive "tape"/tar-paper)?
dutchgray
Dorset. England.
I doubt they would hold up, most are pretty flexible soft plastic and once you cut the ends of they are just a plain tube with a little shape at the ends. Real culvert pipe is either extremely rigid material or corrugated for strength.
king nero
Belgium
You can use those as formwork (with a bit of wooden reinforcement if necessary) to pour concrete around/over them, so you'll basically end up with concrete culverts.
36truck
UP of Michigan
Once you take the ends off they have no strength left to hold up dirt let alone car & truck traffic.
As king nero said use as a ford to pour concrete around with plenty of support inside. Once all done take out the supports & leave the barrels in place.
engineer2
Chicago burbs
Plastic culvert pipe is fairly inexpensive. If you plan to drive vehicles over it, then you have to look at design guidelines.
Sumboodie
AK
King Nero used a Ford to pour concrete? Do mwhat? Haha.
I
IdahoMan
PVC 24"x20' culvert, IIRC, is about $800. :rolleyes:
Plastic barrels will not work, what about wood/logs?
Source: https://www2.gov.bc.ca/gov/content/industry/natural-resource-use/resource-roads/engineering-publications-permits/engineering-manual/road-survey-design/culvert-design/log-culvert-design#:~:text=A log culvert is a log crossing structure,one side of a road to the other.
Also, CL has some used culverts come up from time to time (Ex: A 4'x20' currogated metal culvert for $200). Of course I need a freind who has a vehicle to carry it.
mike93lx
Richmond, VA
Seems like a massive amount of work just to save some money to clearly do it better
ekuhn
Use the right product for what you need. FB marketplace has a bunch of ADS and other assorted drainage piping that I've seen for cheap. Also call a local excavating contractor or two to see if the have any left overs in their yard you can buy for cash. Cash Talks the right talk sometimes.
