Using a 15ga nailer when no room for flooring nailer
branimal
Can I use 15ga 2” nails when I’ve run out of room for my flooring nailer? The other option is to run #7 2” trim head screws into the tongue. I’ve used the trim head screws before it’s a bit tedious.
Will the 15ga 2” nails provide enough holding power?
Last row is going to require glue and face nailing. I’ll cut the under layment accordingly.
mkef
I've done it. I adjusted my depth so the nail didnt blow through the board though. Just hold it and the same angle, add more nails if your super worried.
I had to do it on some floor repair when my wife uncovered wood floors under the carpet, super fun haha
Pen & Wrench
Huron, SD
I did it also, on a new bamboo installation. I had an 18 gauge floor nailer that was shooting a wide slab of an 18 ga "nail". It was blowing out the tongue. I switched to a 16 ga smart point brad nailer, shooting 2 inch nails and it worked fine. If I would have had access to a stapler, it may have worked also.
finn
The UP, God's country
Just pony up for a pneumatic palm nailer designed to shoot flooring nails.
I bought one for a project and it worked flawlessly. It only loads one flooring nail at a time, so I wouldn’t recommend it for an entire floor, but for the last few rows, it’s fast enough. It wasn’t all that expensive, considering the total project cost.
