jmarkwolf
I'm retiring my old Warn 3700 12VDC winch, which I powered directly from those automotive jump packs for over 20 years, to winch small aircraft, lawn tractors, motorcycles, snow blowers, generators, etc., up ramps (max weight 1000lbs). The FWD/REV remote switch for the old winch always worked fine without an in-line solenoid.
This new winch will not be installed on an ATV, and will also be powered from a battery jump pack. The new Badlands 3400 12VDC winch includes a separate solenoid which I assume is to buffer the switches on an ATV, but there is only a pictorial hookup diagram without much explanation, nor any internal schematic.
Did I just get lucky that I never puffed the original FWD/REV switch from in-line current draw in 20 years of operation, and should I assume that I should power the new winch as indicated with the in-line solenoid as depicted?
