Using a clamp meter on a 14-50 240V cord?
lu787a
I'd like to use a clamp meter to measure power on my EV charging setup. My charger is connected to a 240V NEMA 14-50 receptacle. For AC, I understand I need a AC line splitter to measure without opening up the cord and splitting out the hot/ground, etc. I've found plenty of regular 120V line splitters. Is there such a thing for a 240V 14-50 power cord? I don't charge at a very high rate, and amps are generally 20 or under.
Or is there a clamp meter feature that can measure this without a line splitter?
Thanks!
Chuckster in NJ
Hunterdon County NJ
Thanks!
Open the panel and clamp the wires at the breaker.……… OR ………. You can make your own "splitter" with a male and female cord cap and a few feet of wire.
rlitman
Long Island
If you clamp meter a cord without a line splitter, you'll measure 0.
With a 14-50, you have two poles to measure. In theory, there should be no neutral current on an EVSE, so the two legs SHOULD be the same, but until you check, you don't know for certain.
mm08822
Aside from the obvious of measuring the current, for what purpose?
Are you trying to just find the max, learn the charge profile, total charge amount or.........?
Some of this info can be pulled from the evse app if it has one.
u3b3rg33k
most EVSEs don't land the neutral. measuring 1 leg is fine. Screenshot 2025-10-01 at 12.30.33.png
Ive never seen one
Thanks!
nope. the 2 ungrounded conductor cancel each other out so when metered together there is nothing the clamp meter can do nor is there a feature to use. literally there is nothing to meter
