mjoekingz28
I recently just put in my second ever grease tube. Years ago, my first, I greased the rear sway links on a Saturn until they bled. Oops!
Then, on a Dodge Intrepid I went until a slight swell and checked later and it had busted. So I guess there was already enough grease in the boot AND it did not have the vent as some claim.
My truck has eleven fittings and I believe just one on my 3 ton floor jack.
What is the proper technique? It is not as fun as I anticipate because the gun is a lever type, not a pistol grip. So its quite an affair getting the hose on AND holding it flat so I do not lose grease at the contact point, then trying to get light into a shadowy place, then somehow using a hand to pump, whilst against a leg or the concrete floor.
The floor jack works okay. You have to be deft when lowering or it will collapse quickly. My 3/4 ton truck has a chirping going down the road over bumps. I have already greased it and it did look like it had not been current on lubrication.
So, long story short.....when and how? Every year add two pumps? Wait until the steering or suspension creaks or is notchy? How can you tell when to not bother it yet keep it healthy and not dry-rot?
Thanka
Thanka
