Using a microwave to heat a bearing?
930dreamer
Amarillo,TX and Stinnett,TX
I have a large bearing for a 7.5 hp compressor motor, I've used a coil heater and placed the bearing in a metal pan, got to be fast though. Also found this video;
apollo11
State Of Reality
Wow, good idea.
I have a micro in my garage so I don't have to be p-whipped like the clown in the video and wait for my honey to leave.
royesses
I use an old deep fryer filled with motor oil. Set to 300°-325° let it come up to temp and drop it on the shaft.
Jimithing616
Minnesota
Haha funny video. For the size bearings I see in the MC world I just use a heat gun, and then a freezer when I want em to fit in a tight wheel hub or engine case.... fun to see/read how other guys get er done tho. :)
Jimithing616
Minnesota
I thought metal in the microwave is a no-no that ruins it
Interesting point.... I once put an aluminum foil packaged thing of pop tarts in the microwave when I was like 9... sparks and a little flame later my mom was pissed but the old nuke-box was no worse for wear... lasted another few decades in fact
Git
S Cal
Don't think I want to put a sealed bearing in water. I have a shop microwave too.
But you would wrap it in a wet towel?
sealed bearing in a sealed plastic bag... Water boils at 212, so just as it starts to boil
JABgj
So. California
I actually did try the AvE method this past weekend. Sorta works, I got my bearing up to about 150-160 after a 2.5 minute run in the micro. No sparks and I had to use a socket to tap the bearing on, but it was tapping and not beating. Would try it again.
laser3kw
northen IL
be careful if the bearing comes grease packed. Check the operating safe temp for the grease. A lot of low price bearings have grease good to around 185°. Exceed the grease temp while warming the bearing may affect the grease and or the seals to the point of very short bearing life.
kctyphoon
Jersey/Staten Island
I put dog food cans in the microwave all the time.. the metal just can't touch anything else, like the bottom of the microwave without the glass plate inside. Same reason why you can use a metal shelf inside as long as its hung from the plastic clips inside.
77Mini
Ontario Canada
Getting a little off track......try putting a light bulb in the microwave!
Take a regular incandescent light bulb, completely cover the metal base with electrical tape then throw it in the microwave and turn it on. It will light but it will look like a florescent bulb.
Miss the Pontiacs
Saskatchewan Canada
That was what I like about GJ learnt something new today. I probably would have just beat the hell out of it or tried to press it into place with a vice. So what if you froze the shaft and when it was contracted slip the bearing on then.
Firebrick43
West central Indiana
Reminds me of the movie problem child 2 and the guy eating dog food
This is the garage journal? No one has or advocating an skf induction bearing heater?:headscrat
930dreamer
I microwaved the new bearing that replaced this one for 1minute 30 seconds, dropped right on.
metaldad
nw indiana
interesting.
i have used convection ovens, and a oil fryer. i dont like doing it with hot oil.
i have heated up some big bearings (4''and larger id)
VocaTexas
As I understand it, it's sharp points in a microwave that act like little antennae that cause the sparking/arcing. The smooth round surface of a bearing wouldn't have any points to act like an antenna. Still may not be conducive to a long-lasting oven, though.
RedneckWelder
The Ghetto Kingdom of Methlandia
We have a nice bearing heater at work (the bearing is at the proper temp when spit bounces off of it lol ) but we have used a toaster when a field tech has stolen the bearing heater. Have not used a microwave yet
We also have a deep freeze freezer to shrink races, bearings and so on too.
