Using HD-6600-MMA over Delta Dye
Krfjkm
Charlotte / Mint Hill NC
I am building a new shop and used Delta Dye and HD-6600-MMA previously and liked the product. It is a new pour, about 5 months old. I know the porosity of the surface is important. How can I be sure it is porous enough to successfully use this product?
LegacyIndustrial
deerfield, IL
The simplest way to check if the surface is open enough is the water test:
  • Pour a small amount of water (a few inches wide) on the concrete in several spots.
  • If it soaks in immediately, the surface is porous and ready for coating.
  • If it beads up or sits on top, the surface is too tight (common with hard-troweled concrete), and you'll need to diamond grind to open the pores.
Acid etching can work in some cases, but for best results we usually recommend light diamond grinding instead.
Etching only reacts with the surface paste, so it doesn't always open up dense or hard-troweled concrete evenly. A grinder with a diamond wheel gives you a more consistent profile for the DeltaDye and HD6600-MMA to soak in and bond properly.
If you prefer to etch, try our HD357 Concrete Etch
The water test after etching will tell you if it worked and if the water absorbs right away, you're good to go.
