Using natural gas for torch with 2lb?
_strickland
Ordinarily natural gas pressure for residential purposes isn't high enough to be useful for any sort of torch applications, however I do have 2psi service in my home. I'm very good with plumbing but I'm wondering if it is possible to purchase appropriate tools, piping and anything else to make this work - I need some recommendations. I can easily plumb in a line before the pressure regulator in my garage to get the full 2psi output, would this be enough to act in a similar manner as a propane torch for soldering purposes?
liliysdad
A little research says you are going to need a lot more than 2psi. What little info is there seems to indicate that when used for cutting purposes, a booster is used to increase the pressure to somewhere around 25psi at 45ft3/hr.
marinusdees
Edgewood, Washington
In the dark ages, when I was in dental school, we routinely cast gold restorations with residential (school) gas pressure. I have done this subsequently at home. I think it will work, depending on your torch, and material to be soldered. Doesn't take high pressure to generate a hot torch. I doubt it's legal to tap into the gas supply ahead of the pressure reducing regulator.
gmcgeo
It would be cheaper to buy a map gas torch
mike93lx
Richmond, VA
Curious, do you do a ton of soldering in your garage? Having a portable rig is what most people want, but I guess if you are doing stuff like jewelry it could make sense.
Do you consume enough gas that all this is worth the work over a 20lb cylinder?
gmcgeo
Mapp doesn't exist anymore. Mappro is barely hotter than propane and a lot more expensive
yeah, i meant mappro sorry. and for soldering it should be find for his needs.... thats what it seams he needs. to pipe this in natural gas i do not believe it would work. you would have to design set up with the correct orfice and air ratio
liliysdad
I completely missed the soldering part....when someone mentions a torch, I immediately assume a high temp setup for cutting and metalwork, like Oxy/Acetylene.
HoosierBuddy
Southern Indiana
Good luck.
jagboy69
Texas!
I'll be your huckleberry! Watch this very short video of me running my 7" wc natural gas burner! That's less the 1/2 of a psi! I would kill for 2psi natural gas pressure! This burner makes use of half an old microwave blower motor. I use it in my forge and it also does double duty in a glory hole for glass work. The secret is diameter times 9 = inches of mixed airspace before igniting it. I inject gas into a 2inch pipe and that pipe must be at least 18" long before I light it on fire. So far, no boom!
This is just out in the open
Here it is inside an air tank which became my forge.
rayra
Escaped from Los Angeles
Not even remotely close.
A propane torch kit costs $24.
A MAPP gas kit costs twice that, if you need more heat.
/btw, a propane torch head will fit on and work with 1-lb camping propane cylinders too.
DuluthMachineWorks
Duluth, GA
I use an oxy/propane setup, and it takes me FOREVER to go through a 20lb cylinder. Even with the big propane weed burner for preheats, it's reasonably economical to run. Unless I was going to have a permanent gas-supplied setup, like a forge or furnace, I wouldn't bother. A 20lb tank sitting below the work bench with appropriate hoses/regulator/torch would be cheaper and more useful than anything you could run on natural gas.
