Older thread, but running into same thing today. I pulled my 60 gallon compressor out of storage to tie into the 80 gallon 175 psi setup.
I didn't realize it was sold at only "135 psi", tank is plated to 150psi MAWP at 400*.
For what it's worth, the 175 psi compressor's tank is 200 psi MAWP at 400*
I'm not sure if it makes most sense to keep the big compressor at 175 and put a pressure reducer to feed the smaller compressor to 150, or just turn down the big compressor?
The idea with 2 compressors is extra air storage, redundancy, and the added cfm if needed. The idea was to run the big one at around 150 on/175 off, and the little one at 135 on/150 off. So unless pressure drops a fair bit, both won't run at the same time.
Just curious, does that limit change with temperature? Like PEX is rated 100 psi at 180*, but at room temp that rating is 160psi.
400*... I'd imagine the paint would be cooking off the tank!
And also had me wondering, when it's -20*... it still 150psi?
I need to keep the air system at least ~150psi, some of the tires I air up take near 150 psi.
