Using old slab as base for new slab?
gearheads78
DFW TX
I am about to build a new building 40 x 50 over where a 24 x 36 is now. There is not anything wrong with the slab I have and it would be a good thing to get the new building up 4" higher due to drainage. Any drawbacks to doing this way?
IDASHO
Moscow, Idaho
The portion NOT being poured over the existing slab has a much higher chance of settling than the section poured over the old slab.
Gary S
Bismarck, ND
If you don't disturb the soil around the old slab, you shouldn't have any settling to worry about.
I've done 2 garages in the past 18 years. On both occasions I poured new concrete over the old slab and enlarged it. Neither one has has any settling or cracking problems...........yet.
NUTTSGT
Northern Central Ohio
Seeing you're in TX, I doubt you have any freezing/thawing problems like us farther up north. On the house garage, I utilized the old grage floor and poured right over it. I compacted and wet the stone for the new floor with a vibrating compactor. It did crack, right in the relief cut like it should, that was poured 6 years ago.
G
gearheads78
DFW TX
thanks guys...you are right I don't have to worry about the cold. We usually only have a few days a year in the 20's or colder
willymakeit
Springfield Mo.
We are doing this on a large comm. project I am the super on. There are no problems if your org. slab is good. Use plenty of rebar and a vapor barrier that is placed below the concrete. This also has epoxy coated walls and floors.
