Using pennies for a washer.
Briancapecoral
Southwest Florida
Not for anything serious, just anchoring a small plastic shed down with some tapcon screws and they fit the space perfectly. They were not copper, I was kind of surprised when the shavings were silver.
Shiftless
East Bay SFO
Pennies made since 1982 are copper plated zinc.
If you need copper (95% copper that is) find some older ones.
If you are using it to replace a copper crush washer, pennies have not been 100% copper in many years !
nadogail
Coronado, CA
In High School Auto Shop, about 1955 or 56, our teacher used pennies to fill holes where trim had been attached before filling the holes with lead. Bondo was known but it’s use was not considered “professional”
Meursault74
Southern California
Been using a penny as a spacer/shim for a vial crimp for years. Seems the vials we had and the crimper were both at their limits and didn't crimp the aluminum seal quite tight enough. A washer would've worked, but the penny was in my pocket and now it lives with the crimper. Cheapest possible solution.
PCustoms
VT
I glued one to the short foot on the microwave. Handy and just the right thickness to stop the rocking.
NUTTSGT
Northern Central Ohio
Haha. Now that you say that, I put one under the foot of a PC monitor at the station. Not sure if it is still there, there is one guy who would take it out because he doesn't know why it would be there.
glentre
Gloucester, Virginia
I lived in Chile for two years during the early 60's. Due to inflation, they used their silver dollar sized aluminum "pennies" as body fender washers because they were basically worthless. I still have a bag of them I use as poker chips.
Glen
NUTTSGT
Nope, just checked a bit ago. Some cheap ******* stole it.
LS6 Tommy
Northern NJ
Washers cost less to make and are worth more.
There's about 1/2 cent worth of copper and they cost $.02 each to make...
couch67
Ontario Canada
We (Canada) got rid of the penny 7 or 8 years ago. The price of something gets rounded up or down to the nearest nickel if you are paying cash - if using plastic then the price is the price. Its still legal tender, but only the banks will accept them. I certainly don't miss them!
rlitman
Long Island
A buddy used a Quarter to weld up a O2 sensor bung. He did it as joke to see if it could be done.
A few years ago, the thumb rest on my son's clarinet broke at the bend. I ended up making a new one using the back plate from the original, and a modified nickel for the thumb side, silver soldered together. It's actually quite an improvement.
The copper layer on the post '82 Lincoln Memorial back pennies used to be pretty thick. On the shield back pennies it's so thin you can just about see through it.
rlitman
Long Island
Years ago, I saw a chair like this, and wanted to make one:
His current designs use half dollars welded together, but earlier ones used nickels. It turns out that you can put nickels together for $10.33/sq-ft, and that even if you buy in enormous quantities, it's hard to beat that price with stainless washers.
Skiff Builder
Southern NJ Coast
Legend is that many a thrifty Maine boatbuilder would drill pennies out for use as fender washers.
You need lots when your epoxy laminating layers of plywood for your hull bottoms. I thought about it, but stuck to real fender washers. Yeah, my Mother was in the Secret Service......
