Using pipe insulation on wires near hot ducts?
weatherby460
Southern WI
I see people use fiberglass insulation, but it looks kinda tacky. Is it ok instead to use the pipe insulation instead around wires that are close to hot air ducts?
Thanks
Innovate1
How hot are we talking? If it's too hot for the wires I think it would be too hot for the pipe insulation. That stuff melts at a pretty low temp. But I don't really understand the situation you need this for... A bit more info and some pictures would help.
Milton Shaw
He could always use asbestos insulation, and that can handle any heat problem he can think of. LOL
s14kev
I'm assuming HVAC ducts in an unfinished basement? Shouldn't the ducts be insulated instead? Wires generate heat especially when bundled. You want the wires to shed heat not trap it when wrapped up in insulation. Insulating the wires seems counterintuitive
Innovate1
Those look like HVAC ducts and are smooth where the wire touches them. They don't need any protection. If it was at a joint in the duct I would put something to protect them. Probably would use the foil tape for HVAC ducts to cover the sharp edges and call it good.
BD1
north side
You could cut a slot in PVC and set over the wires
checkthisout
What about wires bundled in walls that are insulated with spray foam or fiberglass?
s14kev
****! Instant house fire. :lol_hitti
Just kidding. I agree since we run wires through insulation all the time. The point is more that shouldn't the duct be insulated rather than the wires.
checkthisout
Yeah I don't know. They are within the structure and not up against an exterior wall, crawlspace or heated attic so I don't think much benefit would be had from insulating them.
Leaving them **** like that might make a nice warm spot on the floor for the dog to lay.
