You are getting a little mixed up here.
Bubble foil is the one of the most successful building material hoaxes of the century. Shiny, cheap and easy to install, it is just too good to be true; seriously. Canada's own David Bean, through his web site Healthy Heating, has done an excellent job of exposing the false advertising the bubble-foil people have perpetrated on a ill-informed public.
http://www.healthyheating.com/Page 55/Page_55_o_bldg_sys.htm
The long and short of it, is that aluminum foil is an excellent conductor
and reflector of heat. Unfortunately, you have to pick one. If a radiant slab is in full, direct contact, with foil or some type of "insulating blanket" it will conduct heat directly through the foil or blanket, at what ever the "real" R-value will allow. If the insulation can be compressed or has very little R-value to start with e.g. bubble-wrap/foil, it will make a poor insulator.
Here in Minneapolis, and in our designs around most of N.America, rigid extruded polystyrene (XPS) or expanded polystyrene (EPS) is specified in a compressive strength appropriate to the combined load of concrete and anticipated live weight.
http://www.finehomebuilding.com/item/4822/which-rigid-insulation-should-i-choose
Aluminum is a very good conductor of heat and would likely improve the performance of the slab in terms of thermal equilibrium. However, if you waste time suspending the tube (on chairs) an extended radiant surface below the finished floor is of no value, much like bubble-foil itself.
As indicated, if you need a radiant "barrier" a foil product makes sense, but an air-gap is essential, lest you make a conductor instead of barrier.
We have designed many radiant floors with no insulation in the field of the slab, in mild climates the ground temperature may be high enough to make slab insulation all but useless. This is where a bubble-foil/placebo works best and perpetuates the "industry's" ridiculous claims.
No serious radiant floor heating designer ever specified bubble-wrap or blanket to insulate below a concrete slab. If you want a vapor retarder use 10 mill lapped a half foot. Lapping XPS is another time waster, since the space between panels can be taped, if you must, and no advantage is gained in doubling your labor.
