Using RV antifreeze as airless sprayer storage fluid ok?
remagenman
I have a Graco Magnum X5 airless sprayer and want to put it up for the winter. The sell the blue Armor fluid but I'm thinking it's nothing special if not expensive.
RV Antifreeze is a non-corrosive fluid, what are your thoughts?
Walkers
Cave Creek Az
The pump armor is nothing more than undiluted coolant that does not have the green dye in it. I have been using coolant in mine for years without ill effect.
Stelzer
Portland, OR
Yes, RV Antifreeze is just fine. I have 11 airless rigs that get stored the same way. Pressure washer pumps too.
Pen & Wrench
Huron, SD
I use rv antifreeze on my pressure washer, but I use mineral spirits on my Graco airless sprayer. I'm sure rv antifreeze will work great.
drmarkr
Tucson
Good equipment deserves good protection, not some poorly considered alternative.
Do you ever use SDS's to learn what is actually in the products you're using? It's a valuable skill that can save a chunk of money.
