So i have just recently installed a heater in my garage. The heater has built in heat control but it doesn't have a automatic shut off (which is what I want) so I also wired in a 2-pole switch. Now I have done some research to figure out how to control this heater with a thermostat and I found a couple ways, the first one is with a line voltage thermostat but I have had no luck finding one rated for 30Amps. Now the other method I found was with a contactor controlled by 24v circuit. I have drawn up diagram for both circuits (provided down below) and included a few more details of the supplies i'm using. I have several years of electrical experience and I know the essentials to residential wiring, i'm just not that familiar with installing contactors.
Basically to sum it up I want to ensure that I won't burn my house down.
My questions:
will this layout on my diagram function correctly?
Does it meet/violate standard code?
Does it pose any risks or hazards?
Does the contactor/relay require a specific enclosure or enclosure size?
Is the thermostat wired correctly?
Am I using the right Contactor?
The Contactor i'm using: https://www.amazon.ca/gp/product/B000H5WMXG/?tag=atomicindus04-20
Thanks,
My questions:
Thanks,
