Using weaker phase converter to slow down compressor?
BenKlesc
Boston
Yes I really am considering a rotary phase converter.
I will ask a professional in my area who deals with this. Can get my hands on a used one for a good price.
My blaster with a 3/4" hose and 3/16" nozzle, more CFM the better. 55-65CFM, around what I would like.
This compressor would be about just enough. Also again, I have about 100 amps not being used on my 200 amp box.
Strouty
Southern Maine
Just so you know, the second your tip starts to wear, it will need more CFM since the orifice will be larger.
I bought a duplex compressor to run my big cabinet, but have not gotten to the point that I can use it yet. I don't make any money with my stuff, so things happen really slowly. If I run two 10 hP motors at 940 RPMs on the pump, I can get about 72 CFM.
BenKlesc
Boston
I should post pics some time. I built the blaster on wheels myself from my own design. That's another story.
I have no idea if it works yet but should. Kaboom I hope not. I'm using steel carbide tips, stainless steel pipes. :D
Strouty
Southern Maine
Whatever you do, don't tell anyone that you made the pressure vessel.
So what size PVC are you using for your air lines?
mike93lx
Richmond, VA
This is the same garbage, page after page. You guys that are trying to help are better men than i. You aren't getting through to him. Let him waste his money and enjoy the show
BenKlesc
Boston
Okay I just got the confirmation numbers from Quincy. It would be 50 amps running on single phase power 230V. 36 amps running on 3 phase power 230V.
Not including phase converter...
how do you know this? Have you done a load calc?
Strouty
Southern Maine
I don't know where that number came from, my single phase 10HP draws close to 50 amps. A 15 HP will draw even more.
Strouty
Southern Maine
So I was wrong, it is 40 amps for my 10 HP.
BenKlesc
Boston
I met with someone today who owns a 15HP Quincy running on single phase power. He pointed out that my model also has unloaders, to help reduce start inrush amps.
My electrician seems to think it would be okay on my 200 amp box. Further testing is going to be conducted. I will now be contacting the company who makes those phase converters, for power consumption data.
Strouty
Southern Maine
If you run this on a phase converter, you will need a 30 HP unit at a minimum and that will definitely pull more than 50 amps.
I think the inrush on my 10 HP was something like 230 amps, so you will tax your system substantially. My shop is stand alone, I do not think I would want this type of draw connected to my house panel.
BenKlesc
Boston
Is it also true that 3 phase motors last longer than single phase?
Two options:
Replace with a single phase 15HP 230V motor. (Better option)
Run phase converter off an industrial gas generator. (Bad option)
Strouty
Southern Maine
If you go with a single phase 15 HP motor, you may be able to get a VFD to use for a soft start, since the compressor is normally unloaded the motor would be able to start at less than full power.
BenKlesc
Boston
Of course there is one other option, and that is installing a dedicated breaker for the garage if I want to make this a permanent solution. Even single stage motors take a lot of amperage. That is something to consider down the road if I want to get serious about this setup.
BenKlesc
Boston
Excuse me typo, single phase.
15HP single phase motor would still be close to 60 amps.
If I run a dedicated 200 amp breaker box for just my garage, I would be able to use the phase converter and keep the 3 phase motor. Something to look into, for side business.
brewchief
I had no idea about these, just began researching.
Turns out there are 3 phase portable generators, such as this one below.
https://www.absolutegenerators.com/...25eh-3-4-10-kw-480-volt-dedicated-22-hp-honda
Also another possibility, very expensive though.
If I can find a gas motor that would fit on the compressor, that would work.
You would need a much larger generator to start a 15 hp motor, probably along the lines of a 30-35 kw.
The local sunbelt rental will rent a 90cfm diesel tow behind compressor for around a 100$ a day or 300ish$ a week, I would again suggest that you go rent one and try it out.
Aceman
Eastern Oregon
You really need to contact your power co.
Over here, they want to be notified if you have anything larger than a 5HP so they can verify their infrastructure can handle it.
If you fire that compressor off without notifying them, and you start blinking all your neighbors lights, be ready for them to pay you a visit.
BenKlesc
Boston
Why is that, starting watts much higher too?
My motor is rated @8KW 3 phase power. 18 amps @460V.
larry_g
oregon
Why is that, starting watts much higher?
Search out inrush current and CEMF or counter electromotive force. Short answer is that a non-rotating motor is basically a dead short to the incoming power.
lg
no neat sig line
BenKlesc
Boston
Well I just looked into the option of replacing the electric motor with a gas engine.
I am checking into whether my pump has unloaders, but if you do switch to a gas engine you must have unloaders so you can start the engine without the load of the compressor.
Other than that... If I want to replace a 55-60CFM 15HP with a gas equivalent, I would need a 30HP gas engine that could run @1700RPM or adjust pulley ratio.
More of a pipe dream than anything else that would cost thousands too. So I don't have access to 3 phase power in my area, and don't want to pay the electric bill of running 10,000 watts @ 110 amps. So I'm going to do it the right way, and will be posting back updates on this thread next year.
I will be building an elaborate scheme. I plan on working around the power company to supply 3 phase power to my home all perfectly legal. The power source will fit inside of a small closet, and will power the phase converter and compressor motor with room to spare. Full sails ahead. Place your bets.
strutaeng
Dallas, TX
Basically more of a pipe dream than anything else that would cost thousands too. So I don't have access to 3 phase power in my area, and don't want to pay the electric bill of running 10,000 watts @ 110 amps. So I'm going to do it the right way, and will be posting back updates on this thread next year.
Next year? :lol_hitti
BenKlesc
Boston
I have not confirmed this.
Is watts increased when starting a motor, or just amps?
I know soft starting is about reducing KVA.
Strouty
Southern Maine
I think you need to stop trolling, in fact if you keep this **** up I am going to report you for effing with us.
86turbodsl
I went down this rabbit hole for a long long time. 10HP compressor with 3 phase motor and a 50HP rotary phase converter. It's what i named my shop thread in fact.
After a long time, it became much clearer that on a single phase supply, it makes a lot more sense to move to a 5HP compressor and just double them as needed and downsize the RPC a bunch. I now have a 20HP rpc. With a pony start motor. It makes a lot more sense. You'll probably come to that conclusion eventually.
