I have taken the blower wheel out and now have bought the sprayer and bag. The issue I have now is my minis are mounted up high, I am 78 and I can see getting up and down a ladder is not going to be happening much longer.I use a small electric sprayer and a bib kit I bought on Amazon to do a yearly cleaning on the minisplit in the garage. Even cleaning the filters on the regular it still gets nasty on the blower wheel.
I live in FL it is a swamp. After doing some research the plastic used in the blower wheel is porous and a perfect home for mold. Nothing in the mini evaporator gets mold on it except for the wheel.. People who seem knowledgeable claim it is common in draw through AC designs.The problem isn't the mini it's the RH. Either lower the set point add dehumidifier to lower the RH below 50%. Or lower the set point. Infiltration is not your friend.
Moisture on a AC coil is 100% when the cold air starts to warm up/ mix with room temp rh drops( higher the temp the lower rh). Air temp is easy to drop, latent heat is the hard part.I live in FL it is a swamp. After doing some research the plastic used in the blower wheel is porous and a perfect home for mold. Nothing in the mini evaporator gets mold on it except for the wheel.. People who seem knowledgeable claim it is common in draw through AC designs.
No crawl, house is CBS built in 86, all new windows and doors. Minimal insulation.Moisture on a AC coil is 100% when the cold air starts to warm up/ mix with room temp rh drops( higher the temp the lower rh). Air temp is easy to drop, latent heat is the hard part.
Need to ask our electric provider if they offer a energy audit that includes a blower door test. Will tell how tight the house is. Guess you have a crawl space? Is it sealed with a dehumidifier?
It is not just me with a problem, there are thousands of videos and posts online about mini blower wheels with mold problems.Wouldn’t the UV light degrade the internal plastic and rubber components?……… I know that UV light breaks down the polymer chains in plastics.
Ozone has been known to destroy plastics and rubber too.
BTW! Mold survives on DARK, DAMP area with NO AIR MOVEMENT so if you take away one of these mold will go dormant and will not survive.
TIP! "IF" you have a mold problem in a mini split I suggest checking out a cleaner spray that they use on HVAC systems and use it on a monthly basis.……. Condensate pan tablets and condensate line cleaners will also work to knock down mold.
Check out www.supplyhouse.com
keeping my blower cages clean is a battle as well.It is not just me with a problem, there are thousands of videos and posts online about mini blower wheels with mold problems.
It's a thought. Seen a guy in his shop made a 8X2 foot box over his wall unit. All filterskeeping my blower cages clean is a battle as well.
What I recently started doing is adding a layer of bulk two layer furnace filter on top of the inlet of the wall units. It has made a noticeable difference in keeping the cages clean and you can see the filter material darken from the contaminates they catch. These are in the living space, not a shop. The attached image is similar to what I use, friend that does commercial hvac gave me a few cutoff pieces to try and I'll order me a roll to keep on hand.
I've recommended additional filtration for shop units but got push back on expensive "custom" work.It's a thought. Seen a guy in his shop made a 8X2 foot box over his wall unit. All filters
