UV lights for reactive dye leak detection - What are you using?
Wangstang
Triangle Area, NC, USA
Any advice on which affordable and bright UV lights for reactive dye leak detection would be appreciated. I don't have regular acess to the tool truck guys but if they are a reasonably affordable option I can meet up with one.
Thanks in advance
royesses
I have that same mastercool uv light. Works well so far. Use it for mostly A/C leak detection. Also works well for engine oil uv leak fluids. Exceptional for curing uv curing glue too.
Roy
cajunrebel`
I use a black light bulb from the dollar store in a cheap drop light. Got the bulb on sale after Halloween.
Sent from my E6810 using Tapatalk
W
Wangstang
Thanks guys. On the mastercool light, are you guys having any issues seeing illumination of the dye when in a bright shop or if working outside in daylight?
Jeeper
Round Rock, TX
It works in the brighter light but not nearly as well. I usually turn off lights in my garage when I have to use the stuff. Luckily i have a nice patch on my shoe where I dropped some dye to have as a control. I'd characterize it this way. If the leak is big enough, you'll notice in bright light. It's the small leaks that I'd be afraid of missing.
W
Wangstang
Thanks again folks. I have a UView on the way and I'll see how it works out. Robin Air has a purple handheld that runs off of two CR123 batteries for $70 on Amazon that I may try if the UView isn't bright enough.
