V3 Bug/Suggestion Box
rharman
SoCal
Am I missing something or have all the old signature lines/links not worked since the migration? Mine still shows in my profile but never appears.
Wrench97
Southeastern Pa
How about a screen shot of the Edit signature page?
I'm thinking you have some inadvertent code in there since we are seeing a \\ Roger at the bottom of your posts.
rharman
SoCal
Well, I found the option to show signatures was not checked so I did that and I'm now seeing signatures!
As to the "inadvertent code", I had the dot to force a blank line. The double forward slashes were a standard way of denoting a sig but I did just remove them - although I'm OK with the double backslash. XenForo must have been translating them as they worked fine on the old platform.
Thanks all...
edit: After posting this, I saw my signature and realized that the standard formatting has a separator for the sigs. That's great!!
byoungblood
Berryville, VA
I've run through a few pages of this thread, but didn't see it mentioned.
When I start a new paragraph, if I hit the backspace key, the space between the two paragraphs is deleted. Obviously makes trying to correct any spelling errors/typos a pain in the ****.
Is this caused by any specific extension or is there a known workaround?
Using Chrome on a MacBook Pro.
akasrick
south jersey
sOME TIMES MY KEYBOARD AND ON SCREEN KEYBOARD WILL ONLY LET ME TYPE IN CAPS.
what AM I DOING WRONG? THE CAP KEY IS LOCKED.
AKASRICK
mike93lx
Richmond, VA
AKASRICK
That's your computer, not GJ
What do you mean, the cap key is locked? The caps lock is turned on and you can't turn it off? If the onscreen keyboard won't let you.toggle it either, try unplugging your keyboard and trying again. Sounds like an issue with the keyboard to me
Lassen Forge
This is still going on.... Drives me nuts. I end up putting a lot of spacebar spaces on the blank lines....
Don't know why this happens, but man, it drives me bonkers.....
CHRIII
NE TN
I recently started my first thread. I've gotten several replies and have not gotten any notification (red on the bell). I guess I did not select the necessary option(s). What should I have done?
zanyad
NE Ohio
@Ryan, if a thread hasn't been updated in a while (I think about a month) and somebody posts, the link from the Watched Threads page takes you to the first post instead of the newest unread. Not sure whether this is by design, it's a minor annoyance really.
PCustoms
VT
On my android phone and when i scroll down the top half of my screen jumps a lot like its dragging the page .
Do i need a specific app or something ?
Been seeing this a lot too.
Even worse issue when I "like" a post.
The Cobbler
it does for a while, but then after a period it reverts to the first post . I remeber Ryan saying he was working on that. guess he never figured it out . but in a case like that, there is an option tab to "GO TO NEW POSTS) . when you select that, it takes you to your lsat read post
mike93lx
Richmond, VA
No special app anymore, just your web browser.
I use chrome on android and it's working fine. Does that issue happen for you on any other sites?
I'd clear cookies and your cache (will have to log back in) and make sure your Browser is updated
zanyad
NE Ohio
Yep, that's what I do when that happens. Minor annoyance in the grand scheme of things, but an annoyance nonetheless.
byoungblood
Berryville, VA
Yep, really surprised we haven't gotten an answer to this.
It happens on my Windows machines too, so it just isn't some quirk with the Mac delete key.
@Ryan any comment on how to solve this issue?
