Valspar
willy3486
Middle Tennessee
I used it on a vehicle once and I got it at my usual auto paint store.. IT wasn't bad. Valspar has been around a long time. If I am not mistaken it was used on cars from the 20s,maybe Fords.
Revin68
If I'm not mistaken, Valspar ownes HoK (House of Kolor) and Plasticoat paint companies.
Regnar
I used their Tractor Enamel and Metal Primer. I recommend the Enamel but their Primer is horrible. Took 5 days to harden and took even longer before I felt safe to add the top coat. I use the Enamel on a Industrial CNC router and it is holding up great.
6768rogues
Western NY
Used the TSC Valspar a number of times and it works good. It can't be thinned much so it is thick to spray unless you have the right nozzle on your gun.
Bender78
Northwest CT
TSC Valspar "International Harvester red"
[/IMG]
Crazy Car Guy
morehead ky
a buddy just did his 73 gmc work truck with it and man it looks good its shiny and layed great for a back yard paint job. its not as good as a factory finish but once he rubs the bugs and pollen out it will rival a macco job.
torqueman2002
I've started using it for a few projects recently - both the primer and finish color coats.
I double the 'cure' time for the top coat.
B/4
After
