Frank Dukes
- Joined
- Mar 23, 2014
- Messages
- 178
So i am in need of a decent e torx female socket set but cant spend a fortune. any recomendations?
I have a Lisle set that was cheap and has been fine: http://www.amazon.com/Lisle-26280-Torx-Socket-Set/dp/B0002NYBVO
Sunex makes some good ones too.
Toptul does a set for 19 bucks. Thats on Ebay being sold by a fellow garage journal's dnschmidt too.
Went with this one. thanks for all the replies.
Where are these most used? A few studs on gm accessory drives are the only place I've run into them.
The steps on a Freightliner FLD, exhaust manifold bolts on a Maxxforce, assembly bolts on a few starters, etc...Where are these most used? A few studs on gm accessory drives are the only place I've run into them.
did you notice the part where i bought a US made Lisle set?? I am no full time mechanic. you people crack me up. I guess it should have read as what is a decent non tool truck brand to buy? I was not gonna pay 100 bucks for a set that i will rarely use. thanks for your 2 cents i guess??
Mounting studs for clutch slave on c4 corvette.Where are these most used? A few studs on gm accessory drives are the only place I've run into them.
If you do a lot of work with newer cars, you will be seeing more and more etorx. You will need good sockets and probably wrenches.
My advice is, buy truck tool quality bit and specialty sockets. These sorts of fasteners are used in high torque applications in restricted spaces. I would sooner buy a cheap ratchet handle than a cheap bit socket.
If truck tools are out of the question, certainly don't buy Chinese. Buy US, or European tools first. Taiwan only as a last resort. You can get by with cheap sockets sometimes. Not etorx or bit sockets tho.
Me too. Bought the car new in '89 and sold it a week ago after 192k fun miles with two clutch slaves.Yeah, that's about the only place I've encountered Etorx bolts is on GM/Chevy cars (remember, I'm not a mechanic but I do like to peek under the hood from time to time).
Btw, "clutch slave" sounds like a death metal band name.![]()
I respect your points, but the "coo" and "you get what you pay for" concepts are less acurate today than a decade ago.
...the benefit of e-torx is more surface grip. In turn, it will be a lot more forgiving to a cheap socket than a six point bolt.
You mention c.o.o and using truck brand tools. Did you know vim is the oem supplier of bits for Cornwell, amongst others. As a result, you end up with an import bit in a domestic socket holder when it's the bit that counts according to you. Plus with the world economy, more and more bolts and parts are made overseas.
