Does anyone know what this valve is used for? You can blow air through the bottom but not the top. It's about 2- 1/2 inches long. The body is a hard plastic. You can screw the brass head onto a tire valve stem. Thanks.
You can blow air through the black part but not the round brass head. Maybe calling it a valve is the wrong description. This is how the other end looks.I guess I do not understand your description... You can blow air through the bottom but not the top? I only see one hole which I assume is the top? If it is a valve where is the handle to turn it open and closed?
There is a pin that resembles a tire valve but it can't be depressed. The other end I cannot say what it fits. The black material is a hard plastic. I took a tire valve and it screwed onto the brass end.So it fits a Schrader valve on the brass end. Is there a pin it to depress the Schrader valve, can’t see one?
What is the other end threaded to fit? Maybe a refrigeration recharge kit.
What is black material, plastic or metal?
Seems like nothing else uses the Schrader thread size 0.305x32 , so it’s got to go there.
The pin should be fixed to depress the receiving Schrader valve. I’ve never tried to blow air backwards into an air chuck, but it seems like they always act like a check valve, blowing excess air sideways, not down the hose. Not up to a trip to the garage to check mine now.There is a pin that resembles a tire valve but it can't be depressed. The other end I cannot say what it fits. The black material is a hard plastic. I took a tire valve and it screwed onto the brass end.
