OK - last night, I put 20 psi on several cylinders, and manually pressed open the valves with my hand. I 'burped' the valves numerous times. I then reapplied 100 psi. (I didn't do the burp test with 100 psi, simply because I cannot open the valves against that pressure).
The #1 intake valve is sealing much better, and #6 improved, too. So, clearly, I was able to get some debris out of the valve seating area. The question is now simply - do I just run it, or pull the head and double-check the shop's work, all down the line? I guess that one is for me to answer.
Professional Machine Shop that works on these jobs every day..
