All,
I'm new to this forum and wasn't sure where I should post first, but this thread seems like a good one to start with because I like engines and engine-building
First off, simply lapping valves does not guarantee sealing of the valves to the seats. This is because the tolerance between the valve stem and valve guide. I tried a home valve job on my 96 mazda head, lapping all 16 valves by hand (like 4 hours-my hands were raw) until there was a nice smooth even band on both the valves and the heads.
When I brought the head to the local engine machinist to have it milled (it was slightly warped) I insisted the valves would seal with the lapping I had done. The engine machinist proved me wrong in second flat.
He told me to find the nicest looking lapped valve in install it in the head. We installed the valve into the same place is was lapped and slapped on a spring to hold it in place. We then poured some laquer thinner into the port.....leak city. It was instananeous, lol. The machinist that lapping is a waste of time. After he cut the valves and seats, we tried again is there was no leakage this time.
Both surfaces (valve face and cylinder head seat) need to be refreshed by cutting if new valves (not necessarily newly purchased, just new to that seat) are installed.
Of course, you can say that well since the engine is going to be spinning at 6500 rpm, how much time is there for the air pressure to seep past? Probably not alot, but your missing something more important.
Exhaust valves are constantly exposed to temps of 1500 deg F or more and don't have the cool air/fuel mixture flying past them that the intake valves have. Proper seat configuration of the exhaust valves is critical as about 70% of the heat transfer from the valve to the head goes through the seat.
So sure, just slapping in different valves without proper attention to detail would be fast and cheap, but your going to open yourself up to other issues down the road. I'm sure you don't want to rebuild the head again anytime soon...
Moral of the story is get it done right the first time. And if your a cheap heeb like me, you do as much of it as possble yourself...
Since rebuilding the head on the mazda, I've purchased a Van Norman valve grinder ($200 on Craigslist) and the cool Neway seat cutting tools for working on my Mopar 440 engine/heads. These tools are not difficult to use and you gain a such a better understanding of whats going on and how simple stuff actually is to do yourself.
bmwpower-if you got the head off the car yourself, I see no reason why you wouldn't be able to remove the cams and cut the seats yourself. That tech article on cam removal without the tool made it sound like a piece of cake. I don't shy away from this type of thing because I know that no one is going to take as much care in working on my car than I am, which is why like to do as much on my own as possible. Well that about sums it up. Anyone has any questions, just let me know.
rob
