Valve Spring Compressor?
Deadsquiggles
Chesapeake, VA
Getting ready to rebuild a 302 to go in my ‘84 F150 and I’m looking for opinions for a valve spring compressor since my springs need to be replaced to handle cam lift. What is recommended for a heads-off type? I found one on amazon for around $50 but had mixed reviews.
Djosbun
Autozone is not going to have the valve spring compressor he needs. You are going to want the large C-clamp type. There are different versions available, mostly due to how deep the valve springs are in the cylinder head.
-- Dave
vssjim
McLean Va.
Harry J Epsteins has a Wilde valve spring compressor c clamp style on clearance brand new for 35.00 I think but there web site is being updated and should be back up soon.
Shadowdog500
Down the shore
You want something like this one which gets good reviews.
GEARWRENCH 383D Valve Spring Compressor https://www.amazon.com/dp/B000CO9O2O/?tag=atomicindus08-20
You may want to get or make a stand for the head.
I’ve used the peg type, but this one looks interesting.
COMP Cams 5332 V-Style Steel Head Holder https://www.amazon.com/dp/B001G933TY/?tag=atomicindus08-20
Here is the peg style. More economical. And works fine.
Sealey Cylinder Head Stands https://www.amazon.com/dp/B000RUBAFW/?tag=atomicindus08-20
TOTO
Campbell County, Va
As others have said I would just get a C type from an auto parts store's loaner program. It should work fine depending on the seat pressure of the springs. With that said what condition are the heads in ? Should they have the valves/seats done or at least lapped. Also valve guide condition, checked for cracks and flatness. Just a lot to think about. Good luck with the rebuild.
D
Deadsquiggles
Chesapeake, VA
Heads are in good condition. Seats have already been lapped when I first got them, plus new Viton seals. I just changed my plans for the engine they’re going on so the springs won’t support the amount of lift I’m going with.
@ShadowDog500, I’ll check out that Gearwrench compressor. And the stands aren’t really necessary. Ford small blocks heads stand really nice on the exhaust ports lol
D
Deadsquiggles
Chesapeake, VA
Yeah I’d love to spend the money on an air powered one, but I hope to not have to do this more than once or twice. Plus, I’m not sure when I’ll be doing this. I still gotta but the valve springs I need :lol_hitti
Steve_P
The c-clamp style won't work with higher spring rates - I have an old USA made heavy duty one and it's still not enough. I do those in a hydraulic press.
Ohmthis
Outside of Louisville KY
How much spring pressure is too great for the c type? I have one that I got at sears years ago and have used it to do the heads on a HIPO BB Chevy. It worked, but wore my hands out.
Jagmandave
Overland Park, Ks.
Those are fine for the old two valve heads, but for modern engines with the tiny 4 valve heads I work on (Hondas and Minis and such) they're too big. I'm down to using a large C clamp and a couple of sockets till I buy one that's sized appropriately
Steve_P
Too many variables for a definitive answer, but I'll try. I have an old Craftsman c-clamp style. It's fine for stock or mild aftermarket pushrod cams. I also use it on OHC engines; no issues on them, you can almost do them by hand :). I also have a very HD manual c-clamp one that i bought for hot cams because the Cman wouldn't work. This was the best I could find 25 years ago. It's good, but once you get to about 280-300 lbf open, even it would flex and twist so much that you wouldn't want to use it. I talked to a hi-po engine builder about this and he laughed and said he did the stiff springs in his mill with an adapter. I built an adapter for my hydraulic press to do the same. It's slow but it works.
