valves in air lines
Streetbu
Central NY
Yep, I have ball valves at the end of each line for a drain, also a main shutoff right off the tank before my flex hose to the pipe.
matt_i
There is a "full port" ball valve which doesn't have a smaller diameter than the nominal pipe size like a normal one.
jloehlein
Richmond, VA
Like stated by others, WOG-rated ball valves are fine, and definitely look for full port valves. I ended up using Loctite 567 to seal the threaded connections after finding some leaks with Teflon tape.
Fixnair
Sapulpa OK
Spent 55 years in the air compressor business and have piped many systems. Learned a few things along the way.
First, Teflon tape is a great thread lubricant but a poor choice for a sealant.
Second, ball valves, when opened quickly can cause damage from high velocity flows, especially when used on rotary compressors and desiccant dryers.
Thirdly, when you doubly pipe size you quadruple flow capacity.
Fourthly, using hydraulic hose for compressed air is a poor choice. The oxygen content of the air degrades the lining of the hose and bits of the hose break off and plug orfices.
Lastly, locktite pipe dope is the best for compressed air pipe fittings.
