Vantage MT 2400
92spirit
Montreal
I am looking for the Data Floppy disk that runs on XP I have the connector cable and an XP computer but am missing a floppy disk. would Snapon bother selling a copy or does anyone have one; I would need the setup disk if it is separate. A friend had one, and gave me the cable, but may have tossed the disk. Given that I occasionally work on older cars, the data could be useful
Thanks
Mallen
Thanks
Worst thing they can say is no.
joel63
Central FL
Thanks
I don't believe the MT 2400 Vantage uses a floppy disc.
The updates were done with Updated Memory Cards.
The last Version was the Sixth Edition, around 2001.
Are you looking for Snap — Link Software? "Software (EESP303A) a Windows based program, transfer any printable meter screen to your PC and also you to save images as bitmap files."
92spirit
Montreal
I think that is it but the data for that was on a floppy disc compatible with XP and no longer available online according to SnapOn
92spirit
Montreal
my friend had the disk but almost never used it as it mostly indicated hookup points (pictograms) for tests for different car models and not sure there was much data on diagnoses.
Bobioz1
Northern il. (For now)
Snap-link was a disk program for putting MT2400 capture screens on a computer. For saving or emailing. There was no hook up points or anything else on it. AES had or has a program called WAVE that did the same thing but better. The hook up points are embedded in the version card that goes into the Vantage. I think the MT2500 had a program called glitch snitch. It was useless.
92spirit
Montreal
only used it a couple of times for tests, but don't really have space in single car garage; used to have a dbble garage and did lots; looking for a bigger space in order to set up a lot of things that I can't use: mig welder, air compressor parts washer etc.no ventilation where I am, so mostly storage. would also like to put in a maxjack lift. so lots on hold
92spirit
Montreal
actually got it on facebook locally and got the EV module in the midwest some time later would like to take a course and found a few u-tube videos on its operation; as I am retired, I only know a couple of people with that model but they don't have the complete unit.
