I am finishing a garage/workshop. Standard construction with 2X6 sidewalls, insulation in stud pockets and standard vapor barrier. Wall currently covered with OSB. My question is has to do with a small portion of the wall at the base where there is about 1.5' of concrete block showing. Currently uncovered. I have found a great source of the old style metal siding. It was removed from the interior of a barn on a farm in our area. I want to use this material as a wainscoting on the side walls. Since there is no vapor barrier or wall covering on the exposed concrete block, can I cover that uncovered area with the steel siding and not run into problems with moisture? Any ideas would be helpful. Thanks for checking out the post.
