Alaska4Ever
I live in interior Alaska so needless to say the temperatures here are extreme in the cold category.
My shop is 45 wide by 50 long and 14 foot ceilings with an 8 on 12 pitch. Metal siding with truss construction. Old pole barn that has been converted.
I am finishing out the inside so i can insulate and getting ready to put up the interior ceiling. I have basically two options... Sheetrock the ceiling or put up metal interior panels (basically metal roofing without the UV protective paint)
My questions are:
1. IF i put up the metal and seal all the lap joints is a plastic vapor barrier really necessary?
2. If i put up the sheetrock i do not intend on taking the time to tape and float the joints.. not my DIY expertise obviously i would put the plastic up but just wondering if not taping the joints would cause issue as some point.
Thanks for the help and any advice... just trying to cut cost as much as possible as the overall cost of insulating the ceiling and walls and then electrical and final finish work gets EXPENSIVE.
My questions are:
