kyles974
I've searched but can't find.
If the slab is being poured the same time the footing is being poured, then wouldn't or shouldn't you put a vapor barrier under the footing as well?
I will be epoxy coating the slab, and my concerns are won't moisture get "pulled" in to the slab area if there is no vapor barrier under the footings and only under where the slab is?
