Vapor barrier woes.....
machwon169
I'm building my 50x50 right now... it's Going to be r13 in walls insulation to metal outside then 4 mil vapor barrier then the durapanels over tbag for the walls... that's fine...
My question is when doing the roof how and where do I install a vapor barrier....
My plan was put up the durapanels, lay in the insulation and then 4mil plastic on top of that? Will this work? But will it still condisate up there and drip down onto the plastic and I would never know cuz the f
Roof will be covered....
What would you do?
bullnerd
Jersey
First question you will be asked is where is the building located?
Vapor barrier goes on heated side of insulation.
I'm not a pro, just an enthusiast.
Aquamoose
Location is important. In Florida, the barrier gets placed on the INSIDE!
machwon169
I'm in NJ....
I am worried that the unheated part above the roof will sweat and drip water onto the insulation in the roof
Firebrick43
West central Indiana
If the area above the insulation is vented well it's not an issue. Sweating occurs during large temp swings and high mass items such as the floor and cast iron machinery/vehicles are still cold causing the moisture laden air to parcipitate as it comes in contact with the colder items. By insulating you slow the temp swings and block the high mass of the slab/items from the roof. Any condensations will be much reduced and will be removed if ventilated.
hefnerconstructionlc
Kansas
This above, I have a stick built shop with unfaced r-19 between shop ceiling in this order- tin/insulation/decking/well vented attic space. I heat my shop in the winter, no sweating.
I use small wall mounted electric heater, which also would help to dry the air. Main thing is ventilation, I have soffits and used attic baffles, for air movement. The attic also have roof vents. Your set up will likely be different, but the principles remain.
machwon169
So I have a roof soffet so I'm thinking it's plenty ventilated....
So I guess I will just do roof. Open space then insulation and the metal ceiling panels
Voi
Western South Dakota
There are roll insulations that are designed to not sag in cathedral ceiling type applications and leave an air space. But I don't think they come in lower R values to fit inside of the typical 2x4 upper chords. I think they're R-38 and are made for 2x10 rafters.
Are your upper chords 2x4 or greater? How much of an air gap will you have?
A properly ventilated cathedral ceiling is more important in cold, moist climates like yours. I'd make sure to get this right.
bullnerd
Jersey
You can see some pics of how I did it in my SIG.
I'm in NJ too.
Yes, no bubble wrap.
I've gone up in my attic during these big temp changes that were mentioned and didn't see any water building up, even without any insulation up yet, just vapor barrier.
HotrodHR
North Alabama
The key is to have your ceiling insulted (attic floor) and ventilate the attic as mentioned if you plan to heat or cool your shop...
yeldogt
You will get moisture from the inside -- I would not put the VB on the cold side of the insulation. When using plastic, great care must be given to air tightens and making sure the other side of the plastic can breath. Many rotten building caused from poor plastic vapor installs.
machwon169
The air gap between the ceiling and the slope of roof is going to be about 8 feet of air space
willymakeit
Springfield Mo.
See if there is a envelope consultant in your area. I deal with vapor and waterproof barriers on large below grade and multi story structures.
Buildings need to be thought of as a 6 sided structure to have a high performing structure.
Below grade, walls and roof as a total system.
They can tell you where the dew point is on your system along with how to properly seal it.
In typical systems a 1'' square hole will exchange 32 pints of water per year. With a sealed building and slightly positive inside air pressures great things can happen. Fail and its a nightmare.
Voi
machwon169
Ok so I'm right in saying walls from outside-in...
Metal siding
Insulation
Vapor barrier
Metal linar panel
Then for the roof from outside in
Metal siding
Open space about 8 feet
Insulation
Vapor barrier
Metal linar panels
ard
Metal siding
Insulation
Vapor barrier
Metal linar panel
Metal siding
Insulation
Vapor barrier
Metal linar panels
Sounds right to me.
You want to stop the transport of moisture laden air from a warm area, into a cool area- where it can then condensate out of the air and deposit. (NOT necessarily SWEAT, but over time lead to rust/rot/failure.) I am shocked to read someone say 'its a garage, skip it'. A building is a building, physics is physics- protect it.
If you imagine a wall cross section, picture the inside at (say) 65F and the outside at 32F (or whatever)...now look at your proposed structure- take guesses what the temp will be at various points in the wall. Just behind the metal liner panels it will be 60-62F (guess). Perfect place for VB. But keep going, as you get 'deeper' into the insulation layers, it gets cooler- then just under the outer skin it will be 34-32F. Bad place for VB.
