First I should say I agree with many of the things being said here but this forum opens up a chance for a number of us salesreps to steer people toward "our" systems. Unfortunately for me I did not have Vapor Lock available three years ago to use VL20/20 admixture. THAT is the best way to go. It uses those 17 gal of free water and changes it to additional CSH gel, along the way to vapor proofing your slab, it waterproofs it. I used a penetrating product VL0/0. So flooring has certainly been installed for many years and you have to take some steps to properly prepare your concrete Step 1 is to test the concrete. A petri dish filled with calcium chloride, it’s in the salt family, is a good test. You take that dish, weight it, put the cover over it and moisture vapor emission comes up in there, you then weigh it again and it will weigh more. You then apply a complicated formula to determine how many lbs of moisture/ 1000 sqft you’re taking in. The problem with this test it only looks at the top ¼” to ½” of the concrete, it doesn’t see all that Free Water hanging out at a lower level. So a second test was devised, it’s call InSitu Relative Humidity Testing, you drill a hole down into the slab, about 40% of the thickness, you put this unit in, hook it up to a computer-gizzmo that sends out a signal and the time it takes to get back is a measurement of what it perceives the Relative Humidity to be. And together, these two tests are a reasonable indication whether your slab is too damp or OK to install your flooring. So if you pass these tests, the next step is to install the flooring. Our presentation was done for a large Architectural Firm in Boston which does nothing but Healthcare work, what they told us in the last 4 years, 100% of their slabs have failed these two moisture tests. And they are working with the highest level of moisture sensitive materials in the Healthcare field. So what they do is topically treat those slabs. They put it in the Construction schedule in the front end and they don’t even bother to test the slabs they just treat them. And they just did that to the ½ million square foot Yale Cancer Ctr in Conneticut , and in the process of doing that they spent $2.5 million. So I want to run thru the process real briefly to show you how they topically treat their floors. But remember this process was created as an evolutionary solution and its proven to work and is still the gold standard to stop any moisture from coming thru and ruin any flooring.The first step is to shot-blast with one of these expensive machines and the BB’s leave a bondable texture on the surface. You need that texture in order to put an Epoxy coating on next. This epoxy slows down the rate at which the moisture vapor emission of the Free Water comes out of the concrete. It doesn’t stop it , it just slows it down to a tolerable rate. Since adhesives won’t stick to epoxy you need to then install a self leveling cementitious product. You can then install your flooring. So part of the point of this story is this Firm does this on 100% of their jobs so they can run a tighter construction schedule. And your looking at $5 to $10 / sqft to do that. ALSO, our first and second Permeability Test came back which forces a drop of water at 15 times static water pressure into a 4" core of concrete. Both their results show it would take 6,319 years for a single drop to go thru a Vapor Lock inhanced concrete slab. So, bottom line, in my best professional opinion, if I have the chance to insist on using VL20/20 as an admix, I would. My second option would be, and was to use VL0/0. Your decision is not an easy one based on all of our info, good luck
