I have a 30x30 metal building. Im installing a corrugated ceiling. It will be air conditioned and heated. Do I need to install a vapor barrier on the ceiling. I will be blowing in cellulose
Unless you caulk the ceiling joints, including the edges, I would for the reason Rookie2 stated. That applies to anything - OSB, drywall, etc. Insulation doesn't work well if you let air sift through it.
