pvanderlugt
- Joined
- Nov 14, 2010
- Messages
- 334
Hello everyone, Pete here in Ohio.. I have a electrical motor speed question for someone with more electron knowledge then me..
Background.....I have an old 1920's hay barn converted to a shop....The upstairs I converted to a place for parties and just hang out..
On one of the gable ends I installed 1/3 hp power gable exhaust fan to get some ventilation going.. this is a variable speed 1/3 hp motor..... bought a variable speed controller, same company, for this fan.. everything works great except the horrible noise the motor makes when the speed is turned down.....
Some more reading and researching shows this in normal with the new Solid state controllers.....because at full speed it sounds like a Ultralight airplane, and at reduced speed the motor gets very noisy, this is unacceptable, this is our "living space"... further reading says, that if you get a speed controller with the "preset speeds" instead of variable , the motor will not make this noise, due to the way it works......Ok, I will buy one of those I rather have full speed control, but if that is how it needs to be done to get it silent, ok..... found a 5amp fan 3 speed controller, installed it, works great, no motor noise, except the 2 speed reductions are like 15 and 5% of the original full speed, not even enough to blow the shutters open..
Now for the question, does anyone know of a 3 , or preferable 5 speed controller, that I could use(or a fully variable speed one that will not make the motor sound horrible) that the speed reductions are more linear? Instead of 100-15 and 5%?....all I have around here are big box stores, so will have to order online..
Thanks for the help...
Pictures are what I have know...
Pete
Pete
