DC73
I'm in the planning process for wiring my workshop and wanted to run some code related and other questions by the electrical gurus on the forum.
1) I plan to install two separate 240V outlets. One for a compressor and one for a future welder. What are the box size requirements for the outlets? One of these outlets may be on an outside wall so I'd like as shallow of a box as possible in order to maximize insulation behind the box in the 2x4 walls.
2) As I mentioned above, one 240V outlet will be installed for a compressor. I plan to run #8 romex to this outlet. The other will be for a future MIG welder. A buddy who welds says the maximum size welder for my needs would require a 50A service. I could probably get by with less but might as well consider a 50A service now instead of having to change it later. Question: If I run #6 romex to the welder outlet, and later end up with a piece of equipment that requires a breaker smaller than 50A, will the #6 fit in the lugs for breakers smaller than 50A? If not, what other options do I have to plan for both a 50A service and a piece of equipment that will require a smaller breaker?
3) The breaker panel to be installed on a wall inside the shop will be a 100A Square D 24-space panel fed by a main disconnect on the outside of the building. Will this panel come with a main breaker or is that a separate purchase?
4) Does a garage door opener require a dedicated circuit? At this point, I am unsure as to whether I will install a traditional overhead garage door opener or a side-mount opener so I plan to install outlets for each type. I'd rather not install a dedicated circuit to each outlet if I don't have to. Once I decide on a type of garage door opener, the unused outlet will become a source for a drop light. Thoughts?
Thanks,
DC
Thanks,
DC
