VCT over epoxy...
Luckydevil
Tampa
I've made up my mind to lay down some checkered VCT over the holidays. I'll be sure to do a nice write-up and get a ton of pics.
Right now I have Rustoleum industrial epoxy and I am thinking that the tile glue isn't gonna stick to it very well. Would scuffing the surface by hand be enough, or do I need to rent some heavy duty sander and really lay into the floor?
Thanks guys.
JohnHenrys48
Arizona
I would think you'd want to scuff the surface like you said. I've read on other boards of taking a 4.5 inch grinder and working it over. I'm looking forward to the write up.
Jim
WinFred
to heavyly scratch the surface would be a better way to describe the prep process..
50 grit in a belt sander... light pressure and let the sander do the work.. clean the belt often with a rubber block...
http://www.abrasivesoasis.com/search.asp
or a RT angle grinder works with surface conditioning disks...
http://www.abrasivesoasis.com/products.asp?cat=50
watch out that you limit the amount of heat you generate with the sander... you will get a fussion of frit and destroy yur belts in the process...
an added step for a better finsh floor is to use a scraper on the floor after sanding and just before glue up... there will be a bazillion **** of sanded material that have welded themselves back on to the floor... this will give ya the idea but a scrap piece of sheet metal will work fine..
http://www.leevalley.com/wood/page.aspx?c=2&p=32670&cat=1,310,41069&ap=1
these links are for ideas and subsitutes often work well and can be a buck three eighty cheaper...
